I have finally finished the rough out of the arched dining table frame.
LOML found a pic and I dropped it into Sketchup. Took me a while to find the thick walnut then took even longer to sort out curves, dimensions, radii, etc.
Joinery is M&T, except top rail table cross supports are cross lap joints. M&T joints top are twin tenons (haunched), single tenons on bottom joints. All M&T joints to be drawbored.
Though the long curves were roughed on the bandsaw, I have used a lot of hand tools on this project. Planes, chisels, tenon saws (I need a larger tenon saw), rasps. I have become much better at sharpening and found that fitting joints with hand tools is not so bad. Working with curves takes longer than I had thought. I really respect the skills of guys who can eyeball this stuff.
I think I will make walnut button blocks to secure the top. I may bore and insert dowels through the top cross lap joints to secure it in place since that's not a very strong glue joint (end/cross grain).
The frame top is 71 inches long x 37 inches wide. The top will be a 43 inch wide x 78 inch long oval in walnut. The frame members are 1.75 inches thick. I will now round almost all of the edges to give a softer look.
The pics don't capture the color and grain but I will post some in good light once I finish.
Hope to have this done by Thanksgiving...then will start on chairs. Any ideas on chairs to match?? :eusa_thin
Chuck
View of Top
Closeup Top View
Chuck
View of Top
Closeup Top View
