If you didn't already know, torsion boxes are very strong and in the case of the one I just built, extremely light too!!!
I built the 8' long X 3" thick X 14" wide torsion box below for the article I am working on. I made it from very thin, 1/8" Masonite hardboard, some even weaker thin peg board, and regular ww glue. As you likely know, hardboard this thin is very flimsy and a narrow strip held at one end can snap under its own weight.
For a test, I loaded it at mid-span with over 300# of bricks. I would have used more, but didn't want it to break, in case I need to take more pics of it later.
Here is the internal web. I have already spread glue on the web edges to attach the second skin which is at the right of the pic:
The beam is loaded with 300#+ of bricks (the pyramid is two bricks deep):
Total deflection at mid-span was right at 1/2" with no signs of impending structural failure.
No load:
Under load:
No load:
Under load:
