Miter slots extension table
Joe Scharle
A tip in PWW got me to make something I wanted for a long time. My Shopsmith has a small one that's almost a necessity on the small table.
Some changes include both tracks. That's a 16" wide board shown here.
View image in gallery
Shown here using a miter gage. Easing the corners makes it easier on the user.
Boring an oversized half hole allows for removing/installing miter gages that have the button, from the front.
Joe Scharle
Joe Scharle
Steve, there are at least 2 ways, but first you'll need a board that will 'just' fit in the valley between the saw top and the fence tube and not bottom out when flush with the top of the same tube. Make that board hang past your table ~2in. on each side. Drill a thru hole to accept a Bies or Rockler skinny C clamp. The kind that reaches over a Bies fence. Screw the edge of the table to that while keeping the table tight against the saw top. This will be the same for both methods.
Screw another board of the same length flush against the near side of the fence tube with pocket screws (2 are enough). This will only be necessary if the C clamps are too long to clamp directly on the tube. Only those C clamps will work, because the clamps can't be higher that the table's top.
Or,
You can center a push type toggle clamp on the underside of the table to push against the fence tube.
