Ok..... so i tried the CA glue finish on the pen. I followed these instructions:
-1800 RPM-
Sand with 240, 320, 400 Grit papers.
Wipe down with denatured alcohol (DNA)
-Slow lathe to 500 Rpm. ( or Slowest setting).-
Apply two coats medium CA with Costco Paper Shop towel.
Air dry only betweencoats (NO ACCELERATOR).
Apply Two Coats of Thick CA, as smoothly as possible.
Air dry betweencoats. (If you do need to use a light application of
ACC, I wait at least 1 minute after each CA application, and only
use the Aerosol from a distance. I don't have any issues with cloudiness
or bubbles this way. The pump ACC does not work for me)
-Speed lathe back up to 1800 RPM.-
Sand with 320 Grit(Sometimes 240 grit if I went crazy) to remove any ridges, swirls etc.
Sand with 400 grit.
DNA
MM through 12000.
Here is what I am running into. Does the Thick glue take forever to dry. I followed these instruction and am still waiting for the thick to dry, it has been 1 hour. Is this typical? Am I doing something wrong?
Thanks
-1800 RPM-
Sand with 400 grit.
DNA
MM through 12000.
Thanks
