A ton of work down the can...
Chris C
I made a rookie mistake...I knew better and that's what stings. In all honesty I was never satisfied with this one anyway so it's probably for the best.
It took me all of 45 minutes to thickness sand and bend two new sides. I'm going to fast track this one so I'll stay on my "A" game...
W Burton
HI Chris,
What exactly were you doing when it went wrong? I see the results, and it is indeed painful to look at. I have a guitar in the works myself and I want to make sure I learn from it.
Chris C
HI Chris,
Forgot to trim back the center strip on the back so it would clear the neck block. I thought about it but was so focused on fitting the brace pockets that I waited. And then I forgot it and didn't catch it when I was checking the final fit. Glued the back on and it came out good... Until I saw the 1/16" gap between where the block was resting on the strip.
JohnnyR
Heartache after so much work. So did you just break it apart? If so did you not use hide glue? On the new sides it looks like burn marks from heat bending. Are you going to scrape those out before or after assembly?
W Burton
Okay, that is weird. I did the EXACT SAME THING on the guitar I am working on. I didn't get the center back strip trimmed at the neck block. Fortunately, I was able to go in with a chisel and remove enough of the bottom edge of the neck block to access the center strip and trim it, working through the sound hole. I then cleaned up the bottom of the neck block, mitering it with a chisel so I could get a clean face and glue in a piece at the bottom of the block. I was lucky that it wasn't too far under the neck block, and I could access it for a repair. It isn't pretty, but I am hoping it will work. (Planning to attach the neck this week.)
attachment.php
Chris C
Yep... a couple of light scorch marks. They'll come out easily enough after I get the box closed.
I started taking it apart but got frustrated and smashed it with a carvers mallet. I used titebond. I had been researching hide glue for a different project with the intent of transitioning it into guitar building as well. I may try to incorporate it into this build but not sure at this point.
This one had fought me from the beginning. That's why I smashed it..... Didn't want substandard work floating around with my name on it.
zapdafish
misery loves company
was testing the wedge and apparently grain should be running the lengthwise
attachment.php
Chris C
New back ready for glue. I ran the boards over the jointer to get them close and then finished them with my Miller's Falls #24 (equivalent to Stanley #8).
All glued up....
I can trade you some weights for all that cast iron you are using just for "hold-downs" :rotflm:
danmart77
Dan
attachment.php
All glued up....
attachment.php
Did you use hide glue this time? Musical instruments always need repairs down the road. Yellow glue is not easy- hide glue is simple.
I like the book match figure of the back.
