Well, like I said, cold or not, got me some shop time in today. When you put on the polypro thermals, wool cap, and Gore Tex gloves just to do a little woodworking, you're either determined or not too bright.:jealous: Oh well, been waiting long enough and had to go for it. I took some pics but for some reason they ain't uploading. Keep getting some kind of server error.:BangHead: Anyway.........
I managed to get it all going my way after some adjusting for heights on my horizontal rails and getting things level. In between numerous breaks to go inside and warm up, I managed to grind off about 20lbs. of chips and sawdust from that big Maple slab I've been sanding on for nearly a year now. Man that router sled jig is sure gonna save me some time and money.
Thanks to McRabbit who sent me a recommendation to MLCS http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_bottm.html and their fine shipping service, I was able to try out not only my newly built sled but a router bit too. Both worked great.
I did learn that the next sled I build I'm gonna try to use either HDPE or some sort of phenolic for the router to ride on.:eusa_thin The plywood works okay but I didn't have any wax to slick it up with. Once I applied some lemon oil to it, the router almost moved itself. Also found out the aluminum horizontal rails work much better when they have a little silicone lubricant applied to them. Dang near had to chase it down after that.
I decided to try my hand at this using the bottom side of the slab which had some really nasty chainsaw gouges in it. No sweat. That bit ate right through super dry Maple like butter.:icon_thum Tomorrow I hope to work on the "finish" side and get it nice and level like so I can then worry and fret over what to use for the base support and how to make it. I'm thinking some of the root structure from the tree the slab came from. I'll try to post up pics tomorrow morning early when maybe the net won't be so busy and they'll upload okay then.
All things considered, I had a decent shop day. 8" of snow on the ground and 5" of router shavings on the bench.
