Let's see it.....your bench
golfdad
Co-director of Outreach
Dirk
Do you have to be able to see the top of the bench to post a pic?
KenOfCary
The only way I could post a picture of mine showing the actual bench was to use a picture from right after it was finished being built. Before the clutter started. Maybe I should post an 'after' picture - nah - that would be ugly.
I just got mine done over the Christmas break. It is inspired by Ron Paulk's designs. It is built from 23/32 pine plywood I got from Home Depot for $30/sheet. It has very few voids and is pretty good plywood. The top is bored with 20mm holes created by a Freud router bit and spaced with pegboard and a Woodrave router base. I like the fact that tools can be moved to the lower level to keep the top surface more clean. It rolls on 3 inch totally locking casters I got form eBay. They are pretty good.
bluthart
Brian
Here is a bench I made a few years ago alongside Jeremy (Woodwrangler) after he had decided to do one as well. I'm not really sure where we came up with the design, but I made it out of some Sapele and maple I had laying around. The center trays can be flipped for storage or a smooth work surface, or to allow for middle clamping. Someday I will complete the bottom for better storage options.
FlannelMan
Philip
Here is my workbench I built about a year ago. I was thinking about making a build journal on it. This was my first major project.
It is a Nicholson (English) style workbench. All of the lumber was taken from 2x12 SYP boards from the home store, with the exception of the vise jaw, which is 8/4 white oak. I made this workbench entirely by hand with vintage hand tools that I restored. Not a great picture, but its all I have right now.
golfdad
Dirk
image1 (5).JPG Ok I found a pic when the bench was clean. Built it with SYP base. Top is a solid core door with 3/4 " Oak flooring on top. I will not walk on you !
Cato
Bob
So, mine is pretty basic design and serves as work bench and TS catch. Base is 2x6 and top is from 5/4 ash. I built some overhang on one end for clamping when hand routing and hand planing, etc. Underside serves for some wood storage up to 6 ft. boards.
DaveT
Dave Tenhoeve
Mine is made from Douglas fir 2X12's. This pic isn't the greatest but you get the idea.
aamak
Andy
Here's mine. Split-top Roubo, Benchcrafted hardware and plans. Made from Ash. The split top made it much easier for me to make, because I was able to joint and plane with my Grizzly 12" jointer/planer combo machine. It's a little too big for my 1-car garage workshop, but I don't care. The little white strip at the top of the sliding deadman is a plastic spacer. The deadman was a little grabby, but with the spacer in, it slides easy with one finger.
thrt15nc
Tom
Here's mine. Almost now too heavy to move on the 6 casters. The top was a center island in a house we lived in about 10 years ago. I always think about putting a nice wood top on, but that formica takes a beating. Write on it, glue on it and then scrape it off......
Tom
Alan in Little Washington
Alan Schaffter
How about an adjustable bench made from hard maple and American beech:
From low:
To high:
and in between in 1" increments:
The adjustable legs and ratchet mechanism appear spindly and unstable, but are just the opposite. The bench is rock solid at all heights.
It has three types of vises- a full-width, twin-screw, end vise (with recessed sprockets and chain, and custom cover),
a quick-release face vise,
and a sliding tail vise.
Since they run cross-grain, the end aprons (end caps) were not glued, but left to float to allow for seasonal expansion. There are no exposed bolts or plugged bolt holes to mar the appearance of the end caps. Instead, they are held snug to the bench with hidden bolts which can be tightened easily.
The end caps are positioned with blind, full-width mortise and tenon joints. Barrel bolts (in holes drilled from the bottom of the aprons), threaded rod (in holes drilled in back of the aprons and inserted in a hole drilled in the ends of the bench) and a nut w/washer (in a pocket on the underside of the bench) hold the aprons securely to the bench. Large, hand-cut dovetails keep the apron corners tight.
And then there is the adjustable height assembly table:
Richo B
Richo
Based on Chad Stanton's bench, it is a portable workbench complete with face vise, tail/leg vise, shelf and drawer. Small and portable but perfect for my wood working crafts.
