Gun Cab Delivered!! Few pics
cpowell
Chuck
I've stained the RP edges, glued the end panels, glued the carcass. I also cut and fitted the bottom ply shelf, center shelf (solid) and top.
I have attached a few pics. One shows the molding to go between the sides and top. I will put a VERY slight roundover (1/8 maybe) on the edges of the top.
I included a pic of the frame I would like to use to secure the top. The top will be anchored with the front screws while the holes on the sides and back will be slotted (1/2 inch) to allow seasonal movement. I figured on centering the screws in the slots, giving +/- 3/16th movement either direction. The distance between front and back screw holes is around 13-14 inches. I have debated putting any screws at all on the back but have used this technique in the past and haven't had any problems. Wood is KD oak, with MC at shop equilibrium. Is my thinking sound?
I also included a pic of the cabinet to-date. Hopefully I'll dimension drawers tonight. Drawer box will be DT construction with RP false fronts, per the customer's request. I am still searching for a cam lock that will accommodate the 7/8 drawer face thickness plus 7/8 face frame thickness. The lock is intended to keep little hands out. I can't glue up the drawers until I finalize the lock hardware. Was thinking about THIS cam lock. The Hardware Hut - Product #NCL-C8060-4G-KA413A - National 1-3/4in. Disc Tumbler Cylinder Cam Lock - Keyed Alike (Antique Brass) I haven't installed drawer/door locks before so this represents a new opportunity to screw something up! :lol:
Chuck
Re: Gun Cab WIP Pics
Looks great Chuck. Panels look good, and the sample molding on the side is a nice touch.
I used the cam locks a couple of times in the past. I found out the hard way growing up they are not real secure. My brother would use a screwdriver to turn the entire lock assembly and open it to steal money from me. :-x
One thing you could do is cut a groove in the bottom of the rail for the lock plate to rotate into. A #20 biscuit slot would probably work. That way you could use standard sized cam locks. My .02 for what it is worth.
WoodWrangler
Jeremy
Looking great! I would like to build something similar for my fishing poles ... can't wait to see the finished product!
cpowell
Chuck
Brothers are good for special things like that. Security from thieves is not the purpose so the cam lock should be just fine.
The biscuit jointer is a good idea and pretty idiot proof - not that I couldn't botch it up. I sold my biscuit jointer a while back because I hadn't used it for over a year or more...go figure! :lol: :lol:
I've got a friend in Wilson who may let me borrow one if I ask nice. :-D
Do you know if the depth of the blade is adjustable?
Chuck
NCPete
Pete Davio
And it is still working as well as the day I got it, thank you, Chuck! :eusa_danc
I believe that when adjustments are made for biscuit size, that is basically a depth setting, so, yes????
jeff...
Cranking out some nice stuff there Chuck :icon_thum
IIRC, they come with 2 blades one straight for inset drawers and one offset I believe for 3/4. I think there were a couple of adjustments, but they were not much.
cpowell
Chuck
Re: Gun Cab WIP Pics...Update
I managed to get into the shop last night and again this afternoon.
Got the drawers cut out, dovetailed, sanded and assembled. Mounted the drawer slides. Dimensioned stock for RP drawer faces and door. Routing was a breeze this time around. I guess I've moved up the RP learning curve a little. Sanded panels and stained RP edges then glued up.
Waiting on lock hardware and knobs.
Pics attached.
Chuck
cpowell
Chuck
Hand cut or machine cut dovetails?
Frame and panels look great!
Keller jig. Since the drawers have false fronts I didn't want to trouble with learning to make hand cut DTs. Plus I am at the point on this project where "good enough" applies. ;-)
Chuck
MikeH
Chuck you're making progress and it looks great! Keep the pics coming.
sapwood
Roger
Great progress Chuck! Reads as if you're moving with confidence now. Love the dovetail drawers :icon_thum
Don't slow down,
Roger
cpowell
Chuck
Re: Gun Cab WIP ...Update
I didn't get to spend much time in the shop this past week but managed to put in a few hours yesterday. Ran the drawer fronts, door, inner shelf and top through a 1/8 roundover to just soften the edge a little. Sanded all the door/drawer frames.
I tried installing the molding and ended up ditching it entirely. I just didn't like the look after I got all 4 sides glued up an clamped down. Pulled them off before the tack set and sanded the glue off after a few hours drying time.
Mounted the door and drawer faces, and installed locks and knobs. I discovered a design error on the drawer faces. My plan to attach the false fronts was to use two screws into the top face frame and two screws into the bottom face frame. While I had room to screw into both top and bottom drawer face frames from the inside on the top drawer, I needed another 1/4 inch of frame width to do the same on the bottom attachment on the bottom drawer.
I screwed into the raised panel. I allowed 1/8 inch movement all round and the panel is only 4 inches total width. I don't believe there will ever be a problem with movement. If I had attached the false fronts before I had installed the drawer bottom I would have been fine. :eusa_doh:
The locks I used will need to be modified slightly. I need to add some bends in the metal locking lever to accommodate the installation. Fortunately we have a metal brake at work so that is not a problem.
It's starting to look pretty good now. Have a few errands to run and then hope to stain this afternoon. This is really my first experience with darkening wood...I don't like doing it. PITA and makes the wood look like something it's not. But, since he needs to match color with existing oak furniture it is necessary.
Pics attached.
Chuck
Edit in: Just realized I need to make the feet. Time to find a resource on bracket feet I guess.
NCPete
Pete Davio
there is a 'tip' on making bracket feet on The Woodworking Channel that shows making bracket feet, seems to run every other time I get on there.
nice job, Chuck!
Splinter
Dolan Brown
Chuck, that is looking like a fine piece of furniture. Looking forward to the finish product.
Chuck that is really coming together nicely. A very fine piece that will be cherished for a very long time. Great job! :eusa_clap :eusa_clap
