Here's how to quarter a log the size of which even Scott Smith would have trouble with!
http://harvestingurbantimber.com/?p=115
Tim Taylor and Binford Tool would be proud! :rotflm:
wow that method would have made it easier to remove the transmission out of my car today:rotflm::rotflm:
Hmm, I wonder if Scott Smith has any new ideas :gar-La;
I might have to add trying this to the future "project" list! I've got the powder in stock, just need a way to ignite it. Hmm.... anybody got any blasting caps or primercord? This might be a great NCWW event!
If it is gunpowder just use some model rocket ignitors. You simply attach them to a pair of wires run to a safe distance, then short the two wires to a 6V battery to ignite. Essentially they are electrically ignited matches, the elecricity shorts the heating element which creates a vigorous flame that lasts a second or so -- more than enough time to ignite gunpowder. They are available from most hobby shops that carry model rocket kits and engines. If you want a safety backup, wire a second ignitor to a second pair of wires in the event you fail on the first try. If you purchased a proper 'launch' remote they include a continuity tester that verifies the ignitor is properly wired before you arm the remote.
Primer cord? Why not just shoot at it? :rolf:As a matter of fact...... :gar-La;
Cool stuff, thanks for sharing! It is my understanding that trees that fall has a result of storm winds are often worthless to woodworkers due to "shaken tree" phenomenon; if that is true, I wonder why this same effect is not imparted to the wood using the black powder technique? Just curious.:icon_scra
Donn
