>>> There's oil in poly? How do they make water based poly?
There two entirely different products called "poly".
The first is an oil based "poly" varnish. All oil based varnish is made by mixing a resin like alkyd and a drying oil like linseed oil. The mixture is then heated until the two combine into a new compound called "varnish". The varnish is then thinned to allow it to be brushed. In the case of "poly", "poly varnish" or "urethane", a urethane resin is added to the mixture to improve abrasion resistance. Bottom line, "poly" is varnish plain and simple.
Waterborne finishes are much more complex. There are many chemicals in the formulation and the technology of how waterborne finishes are made and work is quite detailed. Suffice it to say the primary (and maybe only) resin is acrylic. The resin is mixed with other chemicals and solvents. The function of the water is to keep the resin and solvents apart until the water evaporates. Once the water evaporates the other components can come into contact, coalesce and flow out into a film finish. The water is NOT a thinner. The reason for calling these finishes "waterborne" is because the true finishing chemicals are "borne" in the water, not dissolved in the water. Adding water can cause the finish to fail if the components get too far apart when the water evaporates. Some urethane resin can be mixed in the resin mixture and then you have what marketed as "waterborne poly".
A point to be made is that oil based poly and waterborne poly are really two different finishes. The finishes produced are only similar in that they are both clear. Waterborne "shellacs" and waterborne "lacquers" are not true shellac or lacquer. In the manufacturer's opinion, their products have some characteristics comparable to chemical solvent shellac and lacquer but they are quite different. That's not to say that there is anything wrong with these products. Like any finish, some waterborne products are good, some are bad.
Thanks, Good info. :icon_thum
This post is very informative~! Thanks everyone. :eusa_clap
