Cremation Ash Box
bainin
bainin
This one was requested by a family member. A fairly religious family member :)
Interior is around 200cu inches.
Cover/base are hard maple with light pecan stain to warm it.
Sides are goncalo alves using half lapped miter joints. Scottish/Celtic cross also goncalo alves.
Walnut inlays are mostly to hide errors from trenching and blown out dowel holes.
Colored insert is just some pine I had about. Still some poly to do, but getting close to final assembly.
Hope it wont be needed anytime soon!
b
Westpacx3
I like the urn. I made one for my parents last year. Not a fun build but reflective.
How did you cut those mitered half laps?
I'm pretty new to this and have never seen them combined.
The pecan stain is a nice touch as well and definitely softened the appearance.
drw
Donn
Beautifully crafted, I am sure it will be very much appreciated. I like the use of pecan stain to soften the maple...did you do anything to the maple prior to applying the stain? I have had mixed success with staining maple due to blotching, I don't see any blotching on your work.
bainin
bainin
The half lapped miter joints were created with a router bit set from Infinity.
The maple was troublesome-i did a reasonable sanding job, including water wipe to raise grain, then a final sand and mineral spirits wipe. Even still the first stain application left some blotching which I wasn't happy with. I guess the good news is the stain highlights the trouble spots :)
I resanded and mineral spirits wiped again...I think i stopped at 220 grit.
Then re-applied stain and a lot of the blotchiness was reduced. Still some there though !
I'm not sure there is a method in there..but im sure someone knows how best to avoid that . I'd like to know how to avoid the extra labor myself :)
b
