Trout Landing Net
Bugle
Preston
Gonna try my hand at making a trout landing net similar to this one. What glue would you use for the laminated strips? I've seen videos where they used Gorilla polyurethane glue or Titebond III. What is everyone's opinion? TIA.
Danny Batchelor
Danny
I would suggest epoxy. Longer open work time, waterproof and can be thicken in the event you need expansion between strips. Should you choose epoxy, you would need to varnish finished product to prevent delamination.
Wiley's Woodworks
Wiley
This will be a fun project. I watched someone make several until he got it right. A strong suggestion (learning from his mistakes): Make the hoop strips long enough so they extend the entire length of the handle, then insert a piece between the ends so that the 3 pieces glue together to form the handle. If you stop the hoop strips at the top of the handle or try to fasten them to the handle, it's a weak joint and the frame could break.
Bugle
Preston
Good point. Thanks!
Bugle
Preston
Finally got started. Drew the frame template outline on a piece of 3/4 " MDF, (making sure to mark the centerline) cut out the template and fastened it to a piece of plywood. I saved the surrounding cutoffs for glue blocks. The handle is a temporary placeholder.
I ripped 3/4" strips of walnut and hard maple approximately 55" long. I don't have a drum sander so I cut them just shy 1/4 " thick and planed then down to 1/8". I marked the center of each one so I could align them on the template. Since I don't have a steamer either, I put them in a 2" PVC pipe and soaked them overnight. They bent around the frame much easier than I thought they would. Hopefully they will hold enough memory when they are dry and not break.
The small clamps are from Harbor Freight...$2.49 each when you buy 3 or more.
Now to let them dry overnight...fingers crossed.
Bugle
Preston
I'll give it a shot...no promises for picture quality.
The small clamps are from Harbor Freight...$2.49 each when you buy 3 or more.View attachment 198899
Glue up. Painters tape coated with paste wax to prevent the glue from sticking where I don't want.
Bugle
Preston
Done! Fun project. Learned some things along the way such as next time cut the strips longer so they run the entire length of the handle. As you can see from the previous picture, I ended up with a gap between the strips and the handle. My remedy was to continue the "gap" all the way around and fill it with epoxy and turquoise.
I cut a notch in the end of the handle and epoxied a brass rod for attaching a lanyard or retractor. Burned a trout for a little decoration.
Next, I laid out the rubber net to mark and drill the holes for attaching the net.
After the finish was applied (4 coats of poly) I attached the net using the nylon cord supplied with the net bag. The 3 pegs keep the cord tight as I moved along. After each attachment point I remove the first peg and place it in the hole I just threaded.
The finished product.
Linc H
Linc
This is very timely. My son in law asked if I could build him a net...I told no...we can build one together. Let the journey begin. Great tip on length to go all the way down handle. We are looking at plans now to select the net type he wants. I think it will be 16" x 12" I have some cherry, walnut, maple and maybe some other wood long enough. Looks like a good reason to buy yet more clamps... Thanks for sharing Bugle.
drw
Donn
If I made a net as beautiful as the one in the picture, I wouldn't want to get it wet! As others have said, I look forward to seeing pictures of your journey.
