It's been a while since I made an update, but I have made progress. I got the basics of the lathe handed through Carved Tones. I thin I was at least the 4th owner of this thing. I cleaned up the joints and stabilized some things, but wanted something a bit more modern for the spindle. I went through Grizzly's online parts trying to find a good spindle. I had picked out one and ordered it, but after 8 weeks it still wasn't in stock and I had been burned once by their expected date. I did a little googling and found a guy who had the exact same idea. He had the part number of an old model which Grizzly still stocked parts for. I called and sure enough it was in stock. I them bought the rest of the mounting bearings and shafts. I have now mounted the flywheel and did a quick and dirty mount on the treadle. Just enough to make the wheel go round.
There's a bit too much swing in the treadle so I will try to shorten that, but it works pretty well. The pillow block bearings (I did realize how big they are through the dimensions off a bit so the fly wheel doesn't line up quite where it needs to be, but I plan to use an idler pulley on it that should straighten that out. I'm going to have to make the main drive pulley and a tool rest, but I am making progress.
