shop doors
Stuart Kent
Stuart
here is the next pair of doors in process, this pair is for the shop entry. They are mahogany veneered over Spanish cedar stave cores, 8' tall x 2 1/4" thick
attachment.php
karlkoch
Karl
They looked even better in person yesterday. Thanks for hosting the woodturning club, Stuart!
danmart77
Dan
attachment.php
I put these doors together with some yellow pine and beaded pine that HD was getting rid of in the 70 off pile. The glass was the most costly part of the build. They have held up well. I designed the pine tongue and groove panels to come out when the sun beat them to death. An easy "refill" if you will.
Best thing I ever did here was using the strap hinges with pins. Easy alignment in and out.
Door for upstairs. I make these from time to time and they get pretty heavy.
more photos on the Workshop album/Gallery​
danmart77
Dan
those look great, I love the hinges!
If that is something you might want to use, I think I can find the hardware store that I found on line that sells them. They turned out to be the cheapest and strongest option for the jobs I was doing.
They are the easiest hinges to mount heavy doors and the adjustment options make them a great choice. In the photo I don't show the crown molding I put on the top to prevent anyone from lifting the door when closed. The entire shop building was built with "reused" materials with the exception of the siding.
When you are retired, its funny how many things you find when you're not in a rush to get in and out of the stores and lumberyards.
Even the bead board around the return is from the reduced pile at HD.
I had so much at 70% redu ced, I trimmed out the building and filled the doors with it.
danmart77
Dan
I would appreciate the resource - I like them!
Stuart
I bought the parts all separately and found it was cheaper than using many of the "custom strap" retailers. I wound up using an 8" threaded bolt pin and a 3 hole strap to match. I wanted one bolt carriage bolt thru the stile and 2 bolts in the rail. All of the rails are full tenon.
[FONT=Times New Roman, serif]https://www.hardwareworld.com/pc4437m/Bolt-Hook-Zinc-5-8-x-8[/FONT]
[FONT=Times New Roman, serif]https://www.hardwareworld.com/p5gdu45/Screw-Hook-Strap-Hinge-Zinc-Plated-Steel-10
This is the hardware supplier out in Wash state I think it was. You can call and they will help you if you have questions. I strongly encourage you to use the nut threaded pin rods and not the lag bolt type. Its so easy to get these just right.
good luck
[/FONT]
Stuart Kent
Stuart
Stuart
good luck
thanks, I will check it out!
