I got one of these little jewels from WoodCraft to try to improve how I use my vacuum as a DC. They have a new one that comes with two attachments for only $20.
Here it is set up for power carving:
Here it is at the lathe:
It does not suck in all the chips when turning, but does a pretty good job of getting the finer dust. I actually run it through 2 daisy chained ShopVacs:
The big one is not plugged in. It has the hose from the dust source going in to it and the hose from the little one on its outlet port. The big one just has a foam filter and the little one has a HEPA CleanStream. So the big one is my chip collector and a surprisingly large amount of the fines drop in there as well.
One important note about the rigid flex is that it connects like a hose, not an accessory. So you need a connection sized for a hose, or a coupler. I have a coupler that I duct taped to a clamp that came with a chair umbrella or something that is just right for attaching to a work top.
That actually worked out well in general, because I have an adapter and smaller hose:
That I can use for some quick cleaning up and to connect to my uhm, "stationary" belt sander:
One clamp keeps it from going anywhere and it sits right on the lathe bed. Very little dust escapes.
I am pretty pleased with how this all works out for what I do.
