Well I am not sure of the type of wood it was, but peachtree a few months back had their Freud 3 Piece Picture Frame /Molding Set on sale for about half off. After playing around on some scrap wood I found a patter I liked. The Cove & Bead Groove Bit for the in side lip and the Face Molding Bit #1 on the outside. Just played with the spacing. Then cut the miters glued clamped and used the Pushmaster that I had picked up I think at rockler when it was on clearance. Used it to put 3 v nails in each corner. Once dried I add a rosewood stain and then finished with poly. Put on one solid coat and liked the finish as is. I was planning on more coats, but I liked the look after one coat. Figured it is a frame and there should be much wear and tear on it so one coat I hope will be enough.
