My Version of Oland Tool
jimwill48
James
Well got busy this weekend and built my version of the Oland Style Tool.
Shaft is 14" - of L12 Steel .625 in dia.
Handle is Maple 1 1/2" with a 1" - copper ferrul and is 12" long.
Tool Bit is a 1/4" by 2 1/2" HSS
Shaft is held by 2 - 10-32NF Grub Screws
Was only able to use it to turn a little piece of trash pine (chuck of 2x4)
and at least for spindle turning it works great. Can't wait to try it for hollowing both a bowl and end grain. Any who see the pics:
froglips
Jim Campbell
Sweet! Nice job on centering that hole at the end.
Ping me if you ever want to try making a hooked cutter for hollow turning. I've made a half dozen or so. Its a lot of fun to be able to make cutters you can change out.
Enjoy!
Jim Murphy
Fern HollowMan
That's real purty. Allow me to show my complete ignorance of metal-working and tool-making to ask the following dumb questions.
1. Did you have to drill the hole to accept the bit, or is L12 steel hollow to start with? If not, how in the world do you drill such a hole? Drill press? What holds the shaft while you drill it?
2. Was the bit shaped that way, or did you have to grind it to that profile? If you ground it, was it grind and cool, grind and cool, grind and cool on a high speed grinder, or did it take three weeks on a Tormek type grinder?
3. I guess you drilled and tapped for the grub screws. I can see how you'd drill that, with a v-berth on the DP.
4. What's a grub screw? They look like Allen screws to me, does a grub screw have a different type of tip?
5. Is the ferrule just a piece of hard copper pipe (fitting?) hammered/pressed onto a taper on the handle? Or do you buy a ferrule from Aisle 23 at the BORG?
BTW, not only is that a pretty final product, your camera work is excellent. Good clear close-up shots. Thanks.
jimwill48
jimwill48
James
1. Did you have to drill the hole to accept the bit, or is L12 steel hollow to start with? If not, how in the world do you drill such a hole? Drill press? What holds the shaft while you drill it? "No, 12L14 steel is just a easy to work leaded steel, its used to make muzzleloader barrels so it's pretty tuff, this started out as solid .625 stock. I have a small metal lathe and milling machine, I drilled the shaft on the lathe it requires a "S" drill bit."
2. Was the bit shaped that way, or did you have to grind it to that profile? If you ground it, was it grind and cool, grind and cool, grind and cool on a high speed grinder, or did it take three weeks on a Tormek type grinder? "No the its just a blank 1/4" square lathe bit, you have to grind it and yes its grind, dunk, grind, dunk. I started off on a coarse High Speed 6" wheel and finished on a 8" Low Speed wheel. It took about 20 minutes start to finish. I ground it stright across at 45 Degree and then rolled it to get the beval rounded and the tip slighty rounded"
3. I guess you drilled and tapped for the grub screws. I can see how you'd drill that, with a v-berth on the drillpress. " Thats one way and the way I would have if I didn't have a Milling Machine and good mill vise I also used a center finder to find the center of the stock (shaft)"
4. What's a grub screw? They look like Allen screws to me, does a grub screw have a different type of tip? "Just a Allen screw or set screw, its called a grub screw in some metal working circles, size is 10x32NF"
5. Is the ferrule just a piece of hard copper pipe (fitting?) hammered/pressed onto a taper on the handle? Or do you buy a ferrule from Aisle 23 at the BORG? " Just a 1" dia piece of copper coupler, it is shortend to the size I wanted. I turned the tendon just slightly over sized so its a very tight (Tapped On) fit. I then put a couple of dimples on it to make sure it holds"
Thanks for the respone....James :wsmile:
