Magnetic Base Lamp $7.99 @ H.Freight
RandyJ
Randy
Thanks for the heads up, Tommy. Is this offer also available in the brick and mortar locations?
Take care,
gator
George
I have three of those in my shop. The only thing I found is that the 'socket/switch' combo will break down fairly quick (six months to a year depending on use). However, you can buy a good 'socket/switch' at the BORG for about $3. Still about a third of what you pay at any woodworking store. Good deal overall.
George
merrill77
Master Scrap Maker
It is not bad if you like LED lights. I prefer the old tungsten or quartz lights.
LED? What did I miss? It says that it doesn't come with a bulb at all, but the one pictured in the lamp appears to be incandescent.
Re: Magnetic Base Lamp $7.99 @ H.Freight
George
Would it increase base life if a CFL bulb were used? Incandescent lamps generate so much heat that the bases on many lamps fail unbeknown to the owners - usually from using larger than recommended wattage bulbs or inadequate ventilation.
Will this lamp stand up on a wooden table, or does it require a magnetic surface?
Perhaps some of the magnetic paint that is sold at one of more of the BORGs would help in this matter.
gator
George
I suspect that it is heat break-down so a CFL would probably help.
George
