this was my first time changing jointer knives. Rather than buy/use a jointer pal or one-way jig, I came across a thread or two mentioning an easy to build (i.e. cheap) variation on this theme using glass and some magnets. I'm sure others have seen this or similar.
I used some 3/32" thick glass from the HD cut at ~4 1/2" x 9". I glued 2 sets of 6 small neodymium magnets (double-stacked) from Harbor freight about 3/8" from one edge to hold the jointer knives in place and 2 sets of 4 (double stacked) to hold to the outfeed table. The key here is that the magnets are on top of the glass pulling the knives flush with the glass. Having the magnets about 3/8" from the edge of the glass allowed me to tighten the gib screws while holding the knife in place. After some initial tinkering (finding TDC and a spot ~0.002" below), it only took a few minutes to set each knife at 0.002" above the outfeed table (based on my dial indicator). What do others prefer for the height? I've heard dead on flush with the outfeed or 0.001-0.003" above is ok.
