I've never seen a Jointer Pal and don't know how strong the magnets are. I can tell you, these ceramic magnets from Radio Shack are strong. In fact, with three magnets glued to the jig it just about takes two hands to pull it off the jointer bed. I checked the knives with a dial indicator after using the jig and these knives didn't move a bit when tightening the bolts. Considering the strength of the magnets, I didn't think they would.
Ernie
I just Used Earl's Magnet jointer Jig the other day. And let me tell you they work great, but I do have some advice if you happen to do what I did.
My review/how to.
1: First losen all the bolts and pull out the blades and blade tightener and clean sawdust.
2: Lower the set screws all the way down.
3: Lower the outfeed table slightly, if not then like mine the Zero on the infeed was above the mark and still cutting 1/16". :BangHead:
4: Put blade and tightener back in one at a time with blade in same spot each time.
5: Alternatly tighten each bolt slightly, and tightening more little by little. Don't tighten one fully as it will slide the blade either foreward or back, not so sure it makes it higher or lower, but better safe than sorry.
6: Repeat 4 & 5 And raise the set screws till it touches the bottom of the blade, don't want them moving.
7: Now Check to see if each blade will move a block of wood 1/4 and do it in three different places on each blade. Don't want one side higher than another.
If they all seem to move the wood the same amount in different locations on the blade then you should be good to go. If not, then you must have had one blade in a different location than another.:eusa_doh::gar-Bi
I would say these Magnet Jointer jigs work great! Are Cheap! Easy to use! Home Made and easily re-made! And only took me 10 minutes...... each time. As I had to do it again do to the outfeed table being to high and my infeed was way above the zero mark.
I would recomend these to anyone....Now I have never tried any other jig for a jointer, and this is my first jointer...a ridgid 6 1/8"
Hope this helps anyone, someone! Myself in the future! :rotflm:
