glass thickness for cabinet door
joec
joe
I am finishing some cabinets for new media room. I ordered the glass and just specified it was for cabinet doors and did not specify any thickness, thinking it would be 1/8" thick. Now I get ready to install the glass and see it is 3/16" thick. Just wondering if this will be too heavy for the 2" wide wood surround of the glass? My 1/4"X1/4" stays are now proud of the door as well. The doors are 16"X22". Any thoughts?
KenOfCary
16x22 shouldn't be so big that the extra thickness will add too much weight to be handled by the wood rails and styles. The glass will add rigidity and stability to the assembly. I would also have expected to receive 1/8" thick glass, but unless you want to return it you may want to rethink the stays. Perhaps make them wider with a 1/16" rabbit and overlap the wood somewhat. Either return the glass and ask for 1/8" replacement or find an ascetic way to compensate.
I don't think weight will be an issue, but I have only limited experience with glass inset doors. Someone else here may have more practical advice.
Your door is 16" x 22" exterior dimensions and the interior rabbets for the glass panel are 1/4" w x 1/4" deep. Correct?
The 3/16" thick glass is about 3.8 pounds.
http://www.dullesglassandmirror.com/glass-weight-calculator.aspx
Route the rabbets a bit deeper in the frame to set the thicker glass.
not to steal the thread, but how about a picture frame?
How thick should the glass be in a 18 X 24 frame?
CrealBilly
I favor plexi glass since back in the 80's one of my kids broke a curio cabinet glass panel - luckly he wasn't hurt. Every since then its either tempered or plexi glass for me. Now I have grand kids running all over the place and am thankful I made the decision long ago.
SubGuy
Zach
If you wallet can stand it, LEXAN is great. But alas, my wallet cringes when I look at it.
Phil S
Phil Soper
Your glass shop may have concluded you needed tempered glass and most shops will not temper less than 3/16
Skymaster
Jack
3/16 is 1/16 LESS than the 1/4 depth. This is standard, both width and depth to assure NO pressure on the glass
golfdad
Co-director of Outreach
Dirk
Phil said exactly what i was going to say. You probably paid a good bit for it to but is a saftey concern
Sorry, I had my head in the sand yesterday. My statement:
The rabbets should be 3/8" d for 1/8" t glass and 1/4" x 1/4" standards so that all is flush on the back side. Your glass panels are 3/16" t so we're 1/16" proud. :eek:
Route the rabbets an additional 1/16" d and everything will be flush.
gritz
Robert
Glass shops are under a huge burden of liabilities surrounding downstream glass usage. The public knows little of this, but if you ever get a chance to have a frank discussion with an owner, you will be amazed at their exposure. Most will ask you where the glass will be used and supply whatever meets the code or law in that instance. You likely received tempered glass. Look for the hook dimples at the two corners where it was hung as it was tempered.
