was working on a cherry Hope Chest, same one I've messed with now for some time.
The top is 3/4 stock, about 18x36 or so.
The top is comprised of two pieces, the rear section, that fastens to the carcass is about 3" wide, and the wider piece of the top is hinged to it.
The edges of the top have a hand-cut 45 degree(roughly) bevel all around. It was cut "by eye" with a low-angle plane, so it's not "router-bit" perfect, which is exactly what I wanted.
Problem is, when I trimmed the wide part of the top to length, then cut the bevel, I failed to notice that I had, on one end, cut THRU two biscuits that join the boards together!!!!!!!!!!!!!!!!!!1
Now, on one end, theres two little sections of #20 biscuits showing thru the end grain.
The original intent was to leave the end grain below the bevel untouched.
Now, I've got to either:
-Install a narrow trim piece on each end, "breadboard edge, kinda deal.
-Rely on a bit of stain on the end of the biscuits to blend sufficiently as to make t"less than obvious".
-Cut and install two little bits of biscuits in the same location on the other end.
Trimming the top further is not an option.
Likely, the trim piece will get the nod, but I'm none too happy about this.
