It says that it can stop a blade in 1/8 of a second without damage. I am assuming that means no damage to the blade. I wonder how it senses your hand in the proximit of the blade and differentiates between a human and piece of oak. Interesting.
Pete
It has to be able diferentiate between wood and flesh. How would you be able to cut wood with it on the saw?
I assumed the sensors are in the clear saw blade hood and would react to anything above the top surface of the wood being cut. No need to sensor fingers underneath the wood unless someone has a very unusual way of feeding wood into the blade.:gar-La;If so, they'll only do it once.
Ernie
So you have to set this oversized and clunky suction hood/blade guard to the approximate exact height of the stock being cut so that the operator's hand would contact it before it got to the blade. Assumes:
1. You can do the cut you're trying to do with that oversized hood in place.
2. That you're not cutting stock more than finger thickness and you have a screw up where your hand slides in flat on the table rather than the stock.
Looks like it will be continually in the way for a lot of cuts. Leading to the more likelihood (which is the bane of all the TS safety features other than the SawStop one) that someone will just remove the hood/splitter/bladeguard....
My thoughts exactly!:thumbs_upI'll go out on a limb and say the Whirlwind won't be the last solution either, as impressive as it appears. What a country!!
Russ
I assume the hood would be spring loaded and adjust to the stock thickness. Then again, there is probably no one on the planet less qualified to talk about the design of this or any other electrical device - I need to consult my notes to figure out which way to screw a light bulb in.:wsmile:
Ernie
Ladder? - no one told me I needed a ladder.:BangHead:Those are my thoughts.
Which direction do your notes say to rotate the ladder? :rotflm:
Great idea, since this is certainly a skill/asset otherwise not held by our (now >5000) members.I have replied to a request for membership from the inventor of this product. I have offered membership to him. As soon as he replies to my email he will be able to answer your questions.
