I am making a circular table for LOML. She is going to use it on our screened in porch. Since she is going to paint it, I am making in out pof poplar. I glued up the boards and laid the top out. I set up my router-circle jig and attached my PC router with a straight bit. After carefully making a first shallow pass I lowered the bit a little and started a second pass.
I noticed that the cut wasn ot as clean so I shut the router off. It was then that I noticed that the bit was loose. Not thinking I picked up the bit with my left hand between the thumb and forefinger. Guess what happened....I got BURNED :kamahlitu!! The router collet spins at 12000 RPM. With that rubbing against the bit shaft the metal was HOT!! It hurt for a day, but not real visual damage. I dropped it right quick! Today everything is fine.
Just thought I would pass on my lapse as a warning so no one else has to experience it too. Next time I am buying a Router-Stop. :rotflm:
Doug
Doug
