A different technique
FredP
Fred
I'm not sure how this will turn out yet. If it turns out good I'll share the technique. I was going for a antique look so I didn't get too particular with fit and finish. This is with the first coat of waterlox. If I like the finished product I likely make a table base for it ans maybe add a drawer or 2.
Wormy pecan, walnut, maple, purple heart and some other wood that I can't remember the name of.
Can't wait to learn about the process.
FredP
Fred
Well it's looking like it's going to work so here goes.
First I sanded to 120
Then slathered on some mediam CA to mostly fill the worm holes.
Then sanded to 150.
Then I slathered on some spackling. Yeh spackling. (White)
Let dry for a bit.then sanded to 220.
Wiped down and started the waterlox. I'm on the 3rd coat now and it's looking good. If it all falls out well..... we'll see! :p
OMG!
Spackling... as a "feature!"
I think you did before, but talk about the chess board lay-up.
Do you place many small squares on the substrate or do you make strips and cut to width and lay them up or ???
FredP
Fred
Strips, glue. Cut reverse 4.glue. sides and border. Glue. drum sander to Flatten. Glue to substrate. Final cut substrate to fit. Add mitered border. Drum sander. RoS and apply finish. Easy peasy.
