Hey fellow wood nerds!
I got a WS3000 off another member here and haven't used it too much until late. Now I seem to be using it a lot. Curious if anyone has found suitable replacement paper on the cheap (other than what Klingspor offers or WS directly)? I'm assuming I can purchase self adhesive disks and just slap a 1/2" hole in the middle and go but I'm having an issue finding disks in higher grits (like 3200 grit that WS sells direct through Norton). Their micro mesh paper is stupid expensive and if you've used the WS3000 you know that you're basically honing in the same 1/4" space under the disk so that one strip wears out VERY fast it seems.
Lately, I've also been looking at water systems (Tormek, Grizzly, etc.) - don't want to spend the money on the Tormek but it seems like all the other wet options (Grizzly, Rikon, Jet) either don't compare what so ever or have massive wobbles in either the stone or the shaft they ride on. I think I'm going to be using the WS for quite a while... :rotflm:
Thanks it advance for any advice!
