I know this has already been covered once in this thread, and Scott discussed it already, but I think there was a typo still. How does 2" thick oak need 280 days right now, during the hotter faster drying time, vs the same 2" thick oak needing ten FEWER days to dry if you cut it in November, the cooler slower drying time?
The way this is written makes one think that if you want to cut 1" thick oak, then do it now and it will dry faster. But, if you want two inch thick oak, then wait until November, because it will dry faster in November by a margin of ten days.
Methinks this should be 180 days and 270, rather than 280 and 270.
I'm not trying to be argumentative; just trying to clarify because it's not making sense to me. :dontknow:
Thanks
Ben
Ben, it was not a typo. Let me explain it this way.
Envision a 1/4 mile drag race between two vehicles. Vehicle A launches off the line at 100 mph, and then gradually slows down to 20mph, and then slowly speeds back up to 90 mph.
Vehicle B launches off the line at 20mph, and steadily speeds up until it hits 100 mph.
The two vehicles spend the same amount of time at each speed, with the exception that Vehicle A spends one second longer at 20 MPH than Vehicle B, and Vehicle B spends one second longer at 100mph than Vehicle A.
The outcome is that Vehicle B will pass Vehicle A just before the finish line, because it had more time spent at the faster speed, and thus it will finish the race in less time, even though it started at a slower speed.
It's the same thing with the drying schedules in the two examples. Because the November wood spends more time drying at a faster rate, even though it started slow it still dries in less overall time.
Clear as mud? :gar-La;
There is another dimension to all of this too though, and that is the quality of the wood. I can stick 8/4 oak in my kiln and crank the heat up and dry it in a month, but the wood would be damaged beyond use. If the surface dried too quickly on thick oak, it will shrink and check, thus damaging the lumber. It is important to dry it at a slow enough rate so that the interior and exterior of the wood is within few percentage points.
