So after many months of sitting in the garage, I finally decided to put the finish on my cherry occasional table I made in a Woodcraft class. I sanded the table starting at a 120 grit, moving to 150, and then 220. I applied 5 coats of Danish Oil with about 30 minutes in between each coat, per the manufacturers recommendation on the can. The end result is a table that is VERY blotchy and in some places the wood almost looks black. Does anyone with experience working with cherry have any suggestions? Should I have done more sanding with an even higher grit?
