I am about to tackle my first project using a router template guide. I have used pattern bits and flush trim bits for years, but never a template guide.
My question: My bit is 1/4" carbide spiral bit. I have a choice of a template guide with 9/32" ID or 1/4" ID. Does it matter which I use? I will be using a PC plunge router for the cuts. I am afraid that if I use the 1/4" ID guide that the spiral bit may scar the inside as I plunge. Any reason for concern?
I will be routing along the outside of the master cutting 1/2" MDF in 2 passes to create the template. Then I will be using the same bit and guide to cut along the inside of the template to duplicate the master. I only have access to the master for a day, so I can't just copy it multiple times with a pattern bit, not would I want to chance damaging the master.
Any hints?
Any hints?
