Now that I have my own garage bay for a shop, I'm entertaining the idea of building something I have wanted to build for some time, a treadle lathe. I have 2 plans from St Roy, plus other resources around the net. I like Roy's frame design, but even he admits his flywheel is too intricate in his first design and I think I have a better design for a crankshaft rather than bending bolts for his crank arm.
I'm looking for critique on my spindle design. Roy recommends hammering and filing out a drive spur on a bolt with the threads cut off. I'd rather have something a bit more flexible and professional. At one point, drive spurs were available for 1/2" shaft, but it seems no longer. I have however found spurs used on ShopSmiths that will attach to a 5/8" shaft. Also there is a adapter fitting which is threaded. I figure that would be about $48 for both the drive spur and chuck adapter, but the actual spindle shaft would be cheap.
Some of the resources on the web recommended using a spindle from a Craftsman lathe that was available from Sears parts, although no one ever specified the model. I have found one that was available. It occurred to me that Grizzly has some of the best parts services available. Sure enough, I was able to find several spindles available as parts. This has a huge advantage because it gives me a morse taper and a threaded end that could handle a chuck. It may be more challenging to mount though because most spindles don't appear to have the same thickness throughout. I would like to use pillow blocks to hold the spindle since I can adjust them more easily to align the shaft. The one I am thinking of is here http://www.grizzly.com/products/G0462/parts/1 Part 33.
I think I like the idea of using a lathe spindle of common size and TPI since I will be able to use just about any parts.
It's kind of funny that the cost between these works out to be almost even.
