If I might make an alternative suggestion...
You will likely do much better to add polycarbonate (Lexan) windows to the trashcan itself than trying to make your Thien seperator out of clear plexyglass (acrylic).
For my Cyclone DC I use a 33-gal Brute trashcan for the dust bin and have two pairs of windows located at about 2/3rds fill and nearly full. Both windows are made from clear ~1/16" Lexan (polycarbonate) which is much more easily flexed (especially with heat) than acrylic and easily conforms to the curves of the trashcan sides. To seal the edges I used clear silicon sealant (and to pretty the edges up, some aluminum HVAC tape) and 1/8" rivets to permanently secure the Lexan windows to the traschan.
Edit: Use 1/8" backup washers with your rivets so they don't tear though the plastic or thin steel of the trashcan. Suitable backup washers can be purchased wherever you purchase your rivets.
Some Examples:
And has already been mentioned earlier in this thread... It is a good idea to reinforce the trash can with some 1/8"x3/4" aluminum extrusion formed into a hoop and riveted together to prevent the can from crushing under conditions of high vacuum (like all blast gates closed or a plugged hose end). To calculate the dimensions to create the hoop measure the diameter about 3/4" above where you want to place the hoop (you may need up to 3 hoops depending on the construction of your trashcan) and multiply the diameter by 3.14159 (pi) then add about 3" to account for the overlap where you will be rivetting the hoop together. If need be you can rivet several shorter pieces of extrusion together to get the necessary length (I used two 3ft pieces for my hoop). Gently bend the extrusion into a circle, then press fit it into the can slightly below where you measured to place the hoop in compression, then drill 1/8" holes and rivet in place with several evenly spaced 1/8" rivets.
In my photo you can see my hoop installed just a couple inches above the sawdust. Because my trashcan only had one spot weak enough to crush with my 2HP JDS Cyclone I only needed a single hoop (the flared out section near the top of the can essentially reinforces the can as if there were a second hoop located up top, so I did not need one here).
Any how, you would be suprised how easily a good DC or vacuum (esp. shop vac) can crush a perfectly good steel or plastic trashcan, so reinforcing it is well worth the added effort.
Note: the aluminum 'band' up top and vertically down the sides is aluminum HVAC tape with intersections rivetted together for electrical conductivity and one rivet passes through a crimped eyelet to a wire that I then attach to the dust collector chasis ground with an alligator clip (see first photo) to ground the static buildup in the dust bin. With all the swirling dust in the bin you would be surprised how much static can build up if you don't provide a good discharge path.
Hope you find this helpful.
Some Examples:
