I wasn't sure where to put this as it's probably not technically a woodworking question but it's certainly the type of thing we all deal with in our homes (and fix in our shops).
I have a love/hate relationship with one of the "features" in my house: The built-in gas fireplace w/electronics cubby above. Here's a picture.
I hate it because: 1) Does anyone REALLY like gas fire place inserts? 2) Who puts expensive electronics OVER a fire? 3) It's fairly cheesy looking
I love it because: 1) Just flip the switch? Sweet! 2) Ice Storm, no power, no heat? No problem! 3) It's a family room not a formal reception area, with two little kids running around functionality trumps aesthetics, I can pretty it up later. 4) It is a space saver. Since the fireplace and TV extend outside the house I get a few extra feet of usable room width.
So, the challenge of the day is to deal with issue #2, cooking electronics. The problem isn't actually as big as I thought at first. The heat doesn't rise directly out of the firebox. The build meets all of the safety guidelines in the fireplace manual and the floor of the cubby stays quite cool. The problem is that the heat from the fireplace goes up the front face then hits the first shelf and goes into the lower compartments. The equipment there and the bottom of the first shelf can get quite warm. The TV area doesn't seem to be a problem. I can push the TV back a few inches so the heat rises past it and it is a large enough space that it dissipates.
So far I've come up with three options. 1) Buy a larger, metal hood to go above the fireplace which would (hopefully) direct the heat out away from the cubby (basically a larger, uglier version of the gold deflector in the picture) 2) Build some sort of shield (perhaps temporary, something you slide in when you light the fire, or something more permanent in the form of a small mantel or shelf) 3) Prevent the heat from entering the lower compartments by adding a door.
I'm open to brainstorming on all three (or others if you have ideas) but I've lately been spending most brain cycles on #3. I was thinking that a sheet of transparent material (lexan, plexi, glass) that is cut to fit cover the lower compartments (there is a small recess, about 1/4 of an inch, that it could fit into) and hinged for access might be the cleanest solution for the near future. It would allow the heat to travel right on past and shouldn't heat up much itself as it would be a recessed vertical plane. The one additional caveat about this material would be that it would need to not interfere with remote controls....
Anyway, the topic is now open for discussion! All thoughts, ideas, and comments welcome. Much thanks in advance.
