I currently have a workshop that I have outgrown mostly due to a large supply of wood. My current shop only has 8 foot ceilings and it make it problematic to store and move long sock and 4x8 panels. I currently have about 1/4 of my existing shop tied up with wood storage and I also have wood racked under my porch and in the garage.
I am planning to expand my shop with 12' walls and include a finishing room. What are some thoughts as to what I should make sure to include?
Some specifics:
What are the minimum dimension recommendations for a finishing room?
The floor will be joists as opposed to a poured slab like my current shop. Do a need it 12" on center or will 16 be sufficient? My heavy equipment (table saw, jointer, planer, lathe) will remain in the main shop which is on a slab.
My dust collection and compressor are currently outside the shop in a protected but not climate controlled shed. They will need to accommodate the addition. It it a OK for them to remain outside?
I do plan to have a "bay door" which will service something akin to a loading dock as the entrance will be the same level as the bed of my pickup to facilitate loading and unloading without lifting. Should I have a rolling overhead garage door or just a double swinging door? I am leaning toward a double swinging door because it will not require the rolling door infrastructure and provide better insulation but could be talked out of it if there is a compelling reason otherwise.
Since I have my big equipment in the shop do I need to run 220 into the addition?
Lots more to come I am sure. Thanks in advance for your input.
PS: Once it is all done I promise to invite everyone over for a shop crawl.
Some specifics:
