Still working on the play houses I am finally doing the windows. As such, I need to tilt the drill press table on the Shop Fox I bought in a group buy with three other members.
I see that it has two allen screws with lock nuts which seems a bit different, but I figure they are for adjusting the table to level. So finally I pull out the manual and see that I have to loosen the big center bolt. The center bolt is huge. The largest socket I have a 1 1/16"will not even come close to fitting. Pull out the tape measure (the metric one since it is chiwanese) and it is 30 millimeters. So for you other guys that have this unit, if you ever want to tilt the table, get a socket or a wrench to fit it as an adjustable wrench, channel lock pliers, what have you will not work as the space is too tight.
Guess I am going to Sears tomorrow.
