Re: September 24 shop build
Scott, The panel is not installed yet as I still have not determined where the power feed is coming from - either new feed from Progress or from my 400 amp house panel.
I think the extension ladder would be helpful. Sure wish we could use the lift but the ground is too sloped.
Phil, I have access to a scissor lift, which may come in handy for the sections under the gable. Is there room and flat enough ground next to the shop to take advantage of it?
I also have 8' and 12' step ladders, as well as a 22' extension ladder.
I'll bring the coil nailer - just in case (it has a pretty good adjustment on it). I'll have to see if I have any galvanized head coil nails to go with it.
I also have test gear to plug into outlets to verify voltage, proper wiring, ground faults, etc. that I can bring. Is your shop sub-panel hot?
