Scotch-Brite Pads
PeteM
Pete
Do you know that there are 5 different "Gray" Pads with different part numbers and different grits? (I didn't). Not to mention a Light Gray and a Dark Gray and 3 different Maroons. There is also a separate line for woodworking. Here's a pdf with all the details.
  • Scotch Brite Pads.pdf
pcooper
Phillip Cooper
Wow, I'm like Bruce, amazing...simply because I'm looking for this info and here it is!!! Thanks!!!
I use the white ones they are softer, in fact it is what I use to clean my hands with.
Being by the ocean the scotch brite pads and their grades are stocked at fiberglass shops, making surfboards big deal here, in Hawaii.
Might also be @ West Marine or possibly autobody supplies:
7445 - White pad- called Light Duty Cleansing - 1200-1500 grit
7448 - Light Grey- called Ultra Fine Hand - 800 grit.
6448 - Green- called Light Duty Hand Pad - 600 grit
7447 - Maroon pad, called General Purpose Hand - 320 grit
6444 - Brown pad, called Extra Duty Hand - 240 grit
7446 - Dark Grey pad, called Blending Pad 150 grit
7440 - Tan pad, called Heavy Duty Hand Pad - 60-120
Blue Scotch-Brite is supposed to be about 1000 grit. I think this is a home owner marketing thing.
Roy G
Roy
I have the white, the maroon and the gray pads. I bought a box of each many years ago and at the rate I use them I will leave quite a few behind. I guess I use them beyond their usefulness but it's easy to pick it up off the bench and rub down something rather than go to the cabinet and cut off a new piece from my stash. Sloth, I guess.
Roy G
gritz
Robert
I sand through 320, then use maroon, green and light grey when I want to put a polished, reflective finish on certain turned items.
