Router lift
Bigdog72
Geoff
Jessum has a really nice import router lift on sale. My question is (please forgive my newbe showing through): what makes a table with a lift better than a table without? I know the obvious: ease of adjustment. But are there more pluses to consider?
bobby g
Bob
Geoff,
The benefit that I realize every time I use the lift is my ability to make the exact adjustment that I need, to make the cut that I'm after. I don't mean to over simplify.
Bob
eyekode
Salem
I think lifts are more accurate then using a fixed base as well. One of the coolest things IMHO of a lift is there is no need to "clamp down" the router after you adjust it. If you use a fixed router base instead you always have to unclamp, then adjust then clamp it back down. And that clamping changes the height of the bit.
Another really cool thing is easy above the table bit changes (with some models).
Gregory Paolini
Gregory Paolini
I have a few router tables in the shop, and they all have their pros and cons - Here's my thoughts:
I have a Jessem rout-r-lift - With a router lift, you get easy height adjustment, done from above the table, and the router stays locked in the position you moved it to. On my model, I can remove a round insert, and change bits from above the table. I have a quick release collet on mine, BTW. On the other side, you have to make sure that the insert is dead flat with the table around it. And it also helps to make sure your feed rate, or the weight of the router doesn''t cause the axis of the bit to be off center. In addition, the router lift costs $$$ -- Which may or may not be a big deal.
On a fixxed top router table, I know my surface is dead flat, because there's no inserts or plates to level. The router base is just mounted to the bottom of the board. I also know that the bit is perpendicular to the face, becaus of the way its mounted. The cost is very low too - I make my fixed base tops from MDF covered with shellac and wax, which is as slick as glass, and wears pretty well too. On the down side, I have to remove the router to change bits. Depending on which router you use, for example a PC690, you have to unlock, sppin, and relock the router to change heights, all from underneath, while the power switch spins around on you. Some routers make this easier though - My PC890 has a little allen key which sticks thought the top of the table, but I'm still removing it from the table to change bits though.
On another note, my router lift table is huge, giving lots of support, but making it pretty much a stationary tool. My small flat top tables are, well, small - so I can move them around the shop easy, and mount them to a bench.
So, I hope, if nothing else, I was able to muddy up the water a bit more ;)
Seriously though, I have both types, and for a reason. Just weight the pros and cons, and see what works best for you
Best,
Gregory
Glennbear
Glenn
I have never owned a router lift (financial limitations). I use a Freud 1700 series router in my table and it is designed for above the table bit changes and height adjustment without removing the router. While it is true that I have to reach under the table to lock/unlock the router body for bit changes I have not found this to be an insurmountable obstacle. :wsmile:
http://www.freudtools.com/p-260-ft1702vcek-2-14-hp-router-with-2-base-combo-kit.aspx
