Router collets
Cuprousworks
I've had a couple instances of router bit slipping, is there a preferred method or solvant for cleaning collets? I'm thinking mineral spirits would work.
Thanks,
mpeele
michael
acetone will remove any oil or grease, mineral spirits will leave a residue.
If you have ever spun a bit in it you'll need a new collet.
DNA will also probably work. The only time I have had collets slip is when I let the bit bottom out in the hole. One way to prevent this is to put a drop of silicone sealant on a piece of wax paper and let it dry into a small ball. Put it in the router shaft to keep the bit from bottoming out while allowing the bit to slide in a bit as you tighten the collet.
The "space balls" some put into the dado on a floating panel cabinet door to keep the panel centered and not rattle also work.
Rick Mainhart
Rick
Hi Mike,
Router collets (along with router bits) are consumables. They wear out. I've destroyed too many router bits (usually brand new) due to slipping collets. I now keep spare collets on hand and at the first sign of slippage, I crunch them in my metal working vice and then toss them. There is NO way someone will be digging through the trash and "helping" me by "saving" a collet.
I've come to the point where I am going to replace my little Makita router as the last replacement collet I purchased was ... poorly made (but in an official-looking package). Down spiral and compression bits will simply walk out of the collet without so much as a "so long, it's been fun" comment. And yes, my bench is still mad at me over the last incursion.
My Porter Cable 690 and 7518 routers have gobbled up quite a few collets as well ... the 7518 lives in my CNC router, so collet failure generally destroys the work and leaves a sad reminder on the spoilboard (BAD collet !!!).
I've verify cleaning the worn collets does no difference ... I just replace them (and usually the bit that slipped) and move on.
A point of reference ... I do check the bit shank diameters when I have issues with bits slipping, and generally I have to say the bits are not the problem. I also check the cutting diameter to make sure I adjust the tool file for the CNC ... there's nothing more enjoyable than finding several feet of dado's in a project are .003-.005" too narrow because the cutter has worn. (To be fair, I am constantly re-learning that zero clearance tolerance is not a good design feature in any material I work with).
I hope you find this helpful.
Regards,
Rick
bob vaughan
Bob Vaughan
Clean both the socket and the collet with solvent. I like lacquer thinner.
Put the least little bit of graphite around the socket maybe with a rag. Blow it clean with your breath. You don't want graphite inside the collet,
This will allow the collet to slip deeper, hold better and release easier.
This a method Delta suggested when their router collets in a shaper had complaints of slippage. The collet was a Porter Cable style that came on the early 513 routers and similar fill size routers.
Al Olme
Al
Only slightly off topic... I have an ultrasonic cleaner that I used in the past for cleaning small motorcycle parts. It seems likely that it would do a good job on router bits given the right cleaning solution. I looked around a bit and found plenty of choices but the cost was unrealistic...$20/pint. Does anyone know of a generic cleaner that isn't explosive when vaporized, easy to find and reasonably priced?
mpeele
michael
I have put mineral spirits and parts in zip lock bag and sealed. Put the bag and part in the ultrasonic cleaner and filled with water. Clean part in a jiffy.
