Hello everyone. I know it's been a long time since I posted anything, but I need your help to solve a mystery. My objective was to cut a 1/2" deep slot,10" in length; to hog out material prior to using a 'T' slot cutter. The depth of cut was set at 1/8" for the first pass! The problem is, the router bit 'depth' changed - the bit actually raised up! As if the collet was trying to spit it out! I removed the bit, inspected the collet, and tried again. Same problem! I am using a Porter Cable 7518 router, mounted in a table.
When I inspected the router bit, I noticed an extremely small ring depression on the shank. I also had this problem on another project - same type of cut. In that case, the bit actually came through the stock! In both cases, I had the depth set low, with the intention of making several passes to reach the desired depth.
I ordered a new collet, and selected a different bit, a 1/4'' diameter, and had no problems!. Comparing the new and old collets, the only difference that was significant, is the new collet has a tighter grip on the bit when you insert it.
Han anyone had problems with worn or otherwise defective collets?
Any comments an thoughts will be appreciated!
-Don
5/16'' Bit:
http://
-Don
5/16'' Bit:
http://
