Hi all,
I'm making an aggravation board and I need help figuring out how to create the recesses for the marbles to sit in. The board is round, which makes it so I don't have an easy and obvious reference point when locating the spot where the depression will go. I used a graphics program to determine where I want the spots, but even if I mark the locations on the board, how do I get close enough that the rows will look straight?
I don't have a ton of tools now, but I have a plunge router with a bit that will work for this. If anyone has a suggestion for doing this, I'm all ears. The only thing I have thought of was marking the spots and then maybe clamping 2 pieces of mdf or something parallel on either side of the row I am working on and using a bushing to try and get a straight line. Is there an easier/better way?
Someone suggested first making a template out of MDF or something else, but it seems like the only thing easier about that would be that I could use a piece of square material. How do you generally deal with precision placement on round materials?
Thanks,
Thanks,
