Is there anybody close to Mooresville that has either assembled a Rikon BS or a Band Saw in general.This is my first one so I'm a little in the dark and could use some guidance :BangHeadn finishing up the setup on this baby.I'm trying to figure a way to check that both wheels are in alignment with each other.The blade position is different:icon_scra on the two wheels,centered on the bottom wheel but towards the back on the top.Also my tension needle does not read accurately, with NO tension on it at all it only drops down to the 5/8 setting so I was wondering if I should reset that up to the top of the gauge near the 1/8 setting and then go from there.I've not even started on the blade guides yet,will progress slowly.
