A family member recently gave us an older roll top desk that needs a little touch up work.
In taking the desk apart into its different components, I have found the desk top is made of plywood with a hardwood veneer that has numerous scratches. I do not want to sand the top completely down to refinish it in fear of burning through the veneer and fear of not being able to match the finish to the rest of the desk. I have a gel stain that matches the existing finish enough that when used on the scratches it blends in, but I think if I did too large of an area using it that it would stand out from the existing finish. The scratches are really only an issue on the horizontal writing surface. I’m trying to figure out how to get a uniform finished surface so you can write on a piece of paper without the existing scratches showing up through the paper. I also want to select a durable finish so writing won’t create new indentations.
My question to you all is: how would you accomplish getting a uniform solid surface on the desk top? Do you think I need to flood the top with an epoxy type finish that will fill the scratches or can I build it back even with fillers and polyurethane type finish?
Thanks,
Nick
Thanks,
Nick
