Hey Fellas,
OK so we picked the granite today....sapphire blue, COOL lookin stuff
Also mostly have the backsplash stuff picked out.
I've decided to go with curly maple for the cabinets...should look really nice, and Klingspors says they can special order me a batch and generally get very good consistancy.
I have a couple follow up questions though:
1. Current door thickness is .652 inches. Can I go up to .75 without a problem or should I stay the same?
Are they overlay doors? If so the thickness shouldn't matter, especially with a variance of only .098". ¾" is a typical rail/stile stock thickness.
2. Should I really go with 1/4" ply or could I ude 3/8"? Thicker seems like it would be sturdier.
¼" ply will suffice especially if it is glued into the grooves. Your strength will come from the rails and stiles. Using 3/8" ply would compromise the strength of the M&T joint somewhat, unless you used thicker stock.
3. How deep should my tenons be for the rails?
Personally for a door like this I would use a groove and stub tenon. The groove depth and tenon length at 1/2" Gluing in the ply panel will add a lot of rigidity to the door, and the groove/stub tenon is quick and easy to make once you've set up your tooling
Finally, I'm kind of agonizing over the drawer faces. Most are 6 3/16" tall...if I use the same stile and rail width as the doors (2"), the frame surface will overwhelm the panel and I think it will look funny.
I like the looks of solid surface, but I only have a 6" jointer and one large drawer is about 11" wide. I'm sure I could slip the cabinet shop down the street a $20 to face the board for me though. However, warping is a concern as well.
If you stock is properly dried, acclimated to it's environment, and flat when you start it shouldn't warp. You can very easily rip a wider board in half to joint and glue it back together and no one but you will ever know it happened
This fella has an interesting solution - he put the stiles into the rails and made the drawer rails thinner:
Another approach is to use a rail and stile approach, but have the door solid like this (but without the faux joinery inlay - god I hate that). This option looks easiest, but I'm not sure I like the way the drawer looks compared to a solid plank:
