Here is a pet project of mine. It is a cathedral top trunkthat I have been working on. It was drawn using a combination of Sketchup (Tolayout the joinery and other details) and eCabinets. I also drew the lock inSketchup then exported it as a .stl file into eCabinets. The rest was drawn ineCabinets. This Trunk can be cut on our Thermwood router using its modelingfeature. I still have a lot of tinkering to do but as I said it is a petproject.
Hi guys thanks for the complements and feedback. Bill this is still in the design stage. The image that I posted is actually the first draft. I mess around with it from time to time and have since made several adjustments. I do however intend to make this thing someday.Based everyone’s feedback I may be sooner than I think.
Hemerkle In a lot of ways eCabinets is easier to use than Sketchup but at the same time there are a lot of things that sketchup will doquicker. I use eCabinets because that is the program that we use where I work and it is the software that our cnc router uses.This is why I tend to use them both especially on a project like this. It is kind of hard to explain unless you have used both programs. A good example would be tangent arcs. eCabinets does not have a function to draw tangent arcs but Sketchup does. So if I need this type of geometry I tend to draw it in Sketchup then change the number of segments of the arcs to 2 then export the geometry as an dxf file then I canconnect the dots so to speak. I plan on uploading a video on this very subject to my You Tube channel soon but I do have a few that already show how I use both programs. You can click on my link if you would like to check them out.
