is built on a concrete slab- 26 x 36 with block walls and a tin roof, inside wall height is 8 feet. The ceiling is thin plywood and I don't think there is any insulation in there.
I need to build a wall about 6 or 8 feet from the back wall to make a storage room and a small office. Out behind that outside wall i want to build a small shed for the air compressor and dust collector.
What do you think of running the main dust tube down the center of the shop through the rafters? Then I can make drops where the main equipment will be.
Will a dust collector play hockey with a wood stove? Anybody have a set up like that?
Also will have to run conduit and surface mount receptacles on the block walls.
I know it would be better to stud the walls and put up plywood but I don't think there will be any room in the budget for that.
