Been working on a small table that's meant to serve as sort of a mini-bar. It has a couple shelves for bottles and glasses and a butcher block table top. The top and legs are white ash with white oak for the shelves. The wood was leftovers from other projects and was used just because it's what I had. I applied Minwax golden oak stain to add some color. I'm not sure what I'll top coat it with, if anything.
The oak wasn't too bad to deal with, but ash is a major pain. It wants to grab every tool you use on it and tear out left and right. Stainless steel sheet metal doesn't grab a drill bit as bad as this stuff. I gave up on planing it. My irons were sharp enough to shave with and no matter whether I went with the low angle or high angle plane, I couldn't keep it from digging in. I ended up flattening it out with 80 grit and a power sander. It was a learning experience and I think I'll avoid ash in the future.
This is my own design and my first piece that I'll call furniture.
Still need to trim my tenons and dowels plus put a skirt on the top, if that's the proper term. All I've got left is a couple pieces of maple, but I think it will work. Might have to shorten the top a little as my pieces aren't quite long enough. A 4' piece won't quite make 32" x 16". Doh!
