Milk paint vs. odorless latex
I want to odor seal a piece of plain 1/2" plywood to go in the bottom of a blanket chest. It will be the sub-floor for a 3/4" aromatic cedar t&g liner.
Can I use some of today's modern "odorless" latex primers or paints instead of milk paint? Would 1 coat of primer be sufficient for the edges and faces? I'll only be applying a small amount of Titebond II to a few of the cedar boards in a lengthwise fashion. Will it take hold to the primer or should I lightly sand a few primed areas for better bonding?
Thanks in advance.
Why don't you just use shellac. It is about the best sealant for odors and stains. If you're going to cover it this in the t&g cedar all you need is the sealing that shellac can offer. I wouldn't put any finishing product where you are expecting a good glue bond.
NCPete
Pete Davio
with a light sanding, it (Zinser SC) has the same feel, at least to my hand, as a milk paint finish, too.
