Log hewing
Tom Dunn
Tom Dunn
If a person wanted to try their hand at hewing a pine log into a beam, via adz, broadaxe or however, is it preferable to use a green log or something that has dried to a degree?
huckster
Pete
Mike I looked at your picture of the log that you were shaping. Its is a bit of a mystery to me how you flattened that side of the log with the adz. The work piece is set on 2 smaller logs. Do you stand above the log w/the adz or beside it?
Cheers,
~Huck
huckster
Pete
Well I'm glad that isn't you : )
Your right though, that is the picture that I recall. Thats pretty cool.
I can just see myself cutting off myself @ the ankles.
Ahh. Now that I'm looking very closely at it I can see the notch in the two supporting logs. That makes a bunch more sense now.
Thanks,
~Huck
4yanks
Willie
I don't know much about hewing. But, I have done some riving. I would think you would want to work the log green. My reasoning is that, if left on the ground for more than 10 days to 2 weeks some species (oak) will begin to spalt. It is no easy task to throw around green logs either, so I think that working it down closer to its desired dimensions would help with portability, so that it could be stacked properly or worked.
