In our upcoming workshop we will make a corner fan like this. Also, if we have time we can do an oval one:
Never could get the placement of pictures where I want them in this forum, but you get the idea:
Here is a list of some of the stuff/tools you may want to bring. If you don't have them, that's okay, I have some extra stuff and we can share tools.
1. An 8/16 or similar carving gouge. like this:
and a smaller one if you have it.
2. A hot plate and skillet (cast iron preferable, and a few ounces of plain uncolored sand.
3. A small soft-pine board - about 4" X 4" is big enough, bigger is better - need the board to be pine and not hardwood as we will be pushing push-pins into it.
4. A small plywood board for cutting the veneer on.
5. A small hardwood board (or an on going project in which you want to put the inlay).
6. A small quantity of push-pins (10 is enough).
7. Yellow wood glue.
8. Razor or exacto knife.
9. 6" or 12" machinists rule
10. A small block (you can hold in your hand) with some 100 or 150 grit sandpaper - preferably glued to the block.
11. Drafting compass
This stuff is in addition to the other tools (router, small straight router bit, etc) that was previously discussed.
That's about it. I will provide enough veneer and stringing for everyone.
Also, if you have additional carving gouges, please bring them - we can do bell drops too...
