Just a followup as I missed that the question was specifically about the Classifieds.
To rotate a photo that is not already upright (as defined by what your camera considers its fixed "up" orientation, regardless of how you held your camera) it must first be properly rotated on your PC prior to upload and the rotated photo saved back to disk (just rotating in memory will change nothing). However, be aware that not all photo viewer software actually rotates the actual image data -- like the EXIF data, some just make a note to rotate its appearance the next time you view it in that viewer again (or only do so momentarily in memory). That means you need to use an app that really does rotate the photo and then saves the newly rotated photo back to disk for you to upload. Again, on PC, IrfanView is a good free photo viewer that is capable of properly rotating photos and applying a lossless JPEG rotation transformation (you just have to instruct it to apply this transformation).
The other option is to learn what your camera/phone considers to be its upright "home" position and always take photos intended for upload to the web in that specific orientation (sometimes such is literally upside down relative to how you might normally use the phone, but is usually the normal landscape orientation with true digital cameras). What actually defines the home orientation is how the manufacturer installed the camera board when they manufactured your phone or camera, but every photo is physically saved in this one fixed orientation regardless of how you may have held the camera at the time the photo was taken, only a notation as to the camera's orientation gets noted and added to the optional EXIF header rather than the image really being saved in the correct orientation.
Maybe someday they will make cameras that store properly rotated photos to begin with, but very few cameras and phones today do so. The web browser is simply displaying the photo as it was actually uploaded but does not make use of the EXIF extended headers (as it would slow down rendering if all photos had to be fully decoded before page rendering could begin), which is where the rotation instructions are noted by the camera. EXIF aware applications then use that recorded notation to create the illusion of an upright photo despite it being saved sideways, upside down, mirrored or flipped along an axis -- but EXIF headers are not actually a part of the JPEG specification but rather an extension that makes use of the optional header capabilities that many file formats allow (there are also other optional header extensions like IPTC, user comments, user application custom extensions, and so forth).
Anyhow, I hope these two posts help to clear things up. This never used to be a significant issue until recently as even just a couple years ago people would have first copied their photos to their PC prior to uploading. And because just a few years ago very few applications and operating systems were even aware of the optional EXIF extension headers it was very apparent to the user that their photos were in fact upside down and in need of rotation prior to uploading. For better and worse, mobile devices made it easier for people to quickly insert photos into their posts without the intermediary of a PC, but they so thoroughly hide the true orientation of the photo from the user that it leads to a lot of confusion and finger pointing where the server is then blamed for the confusion.
In reality it is a mess that the camera industry inflicted upon the web and it will likely take some years before the countless applications that make the web possible are updated and refined to try and fix this mess that camera manufacturers inflicted upon it...it is just frustrating that so many will blame the web applications for the fault due to how well the fault is hidden from the user's view on their camera or mobile device. Just from the web browser perspective, having to download, decode and apply transformations to every photo and image on a page (and modern sites may consist of hundreds of such graphics) will really slow down page rendering and further increase memory demands, as a browser can not begin rendering a page until it knows the actual dimensions of every graphic on that page and having to apply a rotation means that the readily available dimensions data cannot be trusted until you know what rotation might first need to be applied (and the EXIF data is typically much further into the file than the pixel dimension data, which is typically store very near the beginning of each file).
